4l60e
Old Jul 2, 2007 | 10:03 AM
John Dunn's Avatar
Default 4l60e
Would it be better to install a shift kit or turn the pump up more?
Old Jul 2, 2007 | 10:13 AM
Arc00TA's Avatar
You might get a better response by posting in the automatic transmission section.
Old Jul 2, 2007 | 11:06 AM
cyphur's Avatar
Moved from US&R.....
Old Jul 2, 2007 | 11:12 AM
performabuilt's Avatar
LS1Tech Sponsor
I would advise the shift kit such as the transgo HD2 it addresses many isues not just shift firmness
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 2, 2007 | 06:41 PM
ChocoTaco369's Avatar
Tech Resident
more pressure = bad
shift kit = good
it's that simple. turn up the pressure if you want to smoke your 3-4 clutches. that's what happens when you up the line pressure in a 4L60E - you break the 3-4 clutches and you rev in 3rd gear when you try and shift in overdrive.
put in a shift kit with REASONABLE shifts (i.e. not 3 washers that snap your neck, more like 1 or none) and your clutches will last longer due to faster shift times. not to mention i believe it contains updated springs and all kinds of goodies that benefit your trans when installed properly.
i hope to get a transgo HD-2 kit one of these days. hope this helps!
