Need some help... converter won't lock
Old Jul 13, 2007 | 06:56 PM
steelers71's Avatar
Default Need some help... converter won't lock
Well to start, coming home from the track last Friday night I noticed my converter was not wanting to lock at all and then it throws a SES light. So I get home check the fluid and all looks good. Take the car for a spin the next morning and the SES light is still on and same thing, the converter will not lock. I give a call to my tuner to see if we can hook up and check the code and make a stop while I'm out. Get back in the car and the light is out and the converter is locking fine. Drive around a bit more and it locks sometimes and sometimes it doesn't. Took the car this evening and the same thing. Any ideas what this could be a symptom of? All has been fine with the converter up until last Friday night, even since the h/c went in which was about 2 months ago. Thanks
Old Jul 13, 2007 | 07:14 PM
performabuilt's Avatar
LS1Tech Sponsor
Code be engine misfire codes but get it scanned and you will have the answer the light may be out but the code will still be there
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 13, 2007 | 07:43 PM
steelers71's Avatar
thanks for the reply. I am pretty sure my tuner deleted the misfire codes when we were tuning the car on the street after the h/c swap. I will get it scanned. I did not know I could still retreive the code after the SES light went out. Thanks alot
Old Jul 13, 2007 | 07:54 PM
LS1Tech Sponsor
Yes it will be in the history
let me know what you find
__________________
Call 888-744-6542
Old Jul 13, 2007 | 08:08 PM
steelers71's Avatar
will do, thanks again
