Is This A Shift Cable Problem?
Old Jul 24, 2007 | 01:38 PM
89maro's Avatar
Default Is This A Shift Cable Problem?
Hey guys I got a Turbo 350 Tranny. The car will not move, and the shift lever (b&m ratchet slapshifter) is real loose. I had this problem the other day, and I unbolted the two bolts holding the bracket of the shift cable to the tranny pan. I pulled the cable to the left for two clicks, and pushed it to the right two clicks to lign the bracket to the two holes that keep her attached to the pan. Started her up, and put her into gear, worked perfectly for 2 days (maybe 12miles). Now I have the same problem again, it feels like she's in nuetral when I gas it, but when the pedal is to the floor, she moves at about 2 miles an hour. The shift cable itself is pretty long and the shifter is very loose. But when I fixed it the first time, the shifter became strong and hard to shift, but now I try to do the same thing and nothing. Any help would be much appreciated.
thanks
Old Jul 24, 2007 | 02:25 PM
12secSS's Avatar
This belongs in the Auto Trans forum.
To answer your question, which shifter is it. B&M never offered a "ratchet slapshifter", they do have different models of ratcheting shifters. Each one functions differently from one another, but they all use the same trans bracket, which has no "clicks" for adjustment. Also, it sounds like you are hanging in between gears, this can cause transmission failure if you keep operating it this way, without properly getting it adjusted. Finally, have you contacted B&M's tech support for a possible replacement shifter handle or mechanism?
Old Jul 25, 2007 | 09:29 AM
Patrick G's Avatar
LS1 Tech Administrator
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 25, 2007 | 01:40 PM
89maro's Avatar
well it's a B&M megashifter. And as far as the clicks go I meant the d-clip connected to the cable and tranny, clicked in and out of gear only three times. But anyways I got the problem so-called fixed, but now every gear P R N 1 2 3 the car moves foward. So I thought I got it backwards and moved the lever in the car into 1st (thinking it'd be park) and the car still moves fowards. In reverse the car will move fowards about 3inches and bounce backwards to a stop.
Now i am lost
Old Jul 25, 2007 | 02:48 PM
12secSS's Avatar
So you are not using the supplied cable? You need to put the trans in park with the cable disconnected, place the shifter in park as well. Ensure the trans lever pin engages the trans lever easily, adjust the cable slack if there is any bind. DO NOT INSTALL yet. Now place the trans in 1st gear, place the shifter in 1st gear. Ensure that the trans lever pin engages the trans lever easily. Now place the trans and shifter in park and temporarily install the pin to the trans lever, have a friend assist you in selecting the gear. You will need to verify that the trans is properly engaing the detents inside of the trans while the shifter is in the corresponding gear. You need to verify all the gears. If you experience any mis-adjustment or inproper engagement, you will need to readjust the cable. Good luck!
Old Jul 25, 2007 | 09:29 PM
89maro's Avatar
I'll give it a shot first thing in the morning. Thanks dude I do appreciate man
