Hard Shift from 1st to 2nd on auto tranny
Just got a 1998 Z28 and I find that it shifts quite hard(firm) from 1st to 2nd gear.
It is a real push in the back when cruising at traffic speed.Not really comfortable.
When I really step on it ,the shifts up is so hard that the back tends to break-out.Even with asr...
Is this normal ?
Or can I do something about it ?
For the rest I love it!!!Just have it for 10 Hours.
Many thanks
Martin
If it has a shift kit, all you can do about it is take it out. Flush it anyway just so you know where you stand on maintenance.
So clean ATF
,what type and how to flush?
also like stated check the tranny mount....and fluid levels
TSB # 01-07-30-023A
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)
1996 Buick Roadmaster
1996 Cadillac Fleetwood
1999-2000 Cadillac Escalade
1996-2000 Chevrolet Camaro, Corvette
1996-2000 Pontiac Firebird
1996-2000 Chevrolet and GMC Light Duty Truck Models
1996-2000 Oldsmobile Bravada
with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 1999 (Julian Date 9015)
This bulletin is being revised to update the Parts Information.
Please discard Corporate Bulletin Number 01-07-30-023 (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated.
Diagnosis
Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs.
The scan tool may show a DTC P1870 set as a history code.
A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F).
Cause
The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Important
DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code.
When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result.
This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code.
When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. These valves are used in all transmissions produced after January 15, 1999 (Julian Date 9015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important
If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body.
Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears).
The torque converter is not blue or overheated.
The transmission fluid is not burned or has no burned odor.
The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments
So clean ATF
I had a BG flush done, but I don't know whether that's available in Holland. If you search on trans flushing you'll hear tons of differing opinions on whether it's good or bad. Since your mileage is low I personally wouldn't hesitate to flush it. With 46k on the clock, it's highly likely that it's still the original fluid.
Fresh fluid made a HUGE difference in shift quality with my car. Everybody loves firm shifts at WOT, but not necessarily at part throttle.
If I'm in your shoes, it's a good maintenance item at the very least so you know when it was last done. I would bet money that it will fix your shift quality issues. When you do it, make sure you insist on replacing the fluid with Dexron 3, non-synthetic ATF.
Some people just drop the pan, change the filter, and refill. If you go that route keep in mind that you're only changing like 1/3 of the total fluid. The tranny holds something like 15+quarts.
Congratulations on your new toy.
Did a fluid change 300mi ago now,the oil was deteriorated with black residue under in the pan.(no flush).No large metal particles...Right after this refreshment,
not much change in shift quality.Must say gradualy gets better now.Only 1of 5 1-2 shifts is rough.
Want to change fluid again soon,good or not?
Also notice some play in the driveline at shiftpoints,what can that be or how to find out?
The firmer the shift, the less slipage, I know why my setup shifts this hard, you should find out why yours does too. If there is a shift kit or aftermarket servo, all is well, if not, there maybe an underlining problem. Slipage equates to heat, and transmission wear, my digital trans temp guage tells me that all is well.
SteveC
Go to the autoparts store and get a can of MAF cleaner. I bet your MAF is dirty. When your MAF sensor gets dirty, it causes the transmission's line pressure to go through the roof and causes harsh shifts. This can lead to burnt clutches, so do this maintenance ASAP.
I'm willing to bet it's not a shift kit OR an aftermarket tune, but a simple dirty MAF sensor.
