Tranny HELP!?
Old Jul 25, 2007 | 01:51 PM
airmaxon1's Avatar
Default Tranny HELP!?
hey guys, getting ready to drop the pan to change out filter and fluid on tranny, would it be easier to but the back up on ramps or the front? I cant get the ramps to even stay when i try to put up the front, they just keep sliding. Any suggestions? Thank You.
Old Jul 25, 2007 | 04:59 PM
joecar's Avatar
It's easiest using 4 big stands if you have them... then you can use the speeder wrench on the pan bolts, goes very quickly;
With 2 stands and 2 ramps... try getting the end of the car with the trans higher;
To get the ramps to stay put on the ground, place some carpet pieces under the far end of each ramp.
