RPM drop between gears
Old Jul 29, 2007 | 03:06 PM
NC98Z's Avatar
Default RPM drop between gears
Ok I've got a Performabuilt Stage 2 4L60E tranny and I have 3.73 gears. How do you go about figuring out how much the rpms are going to drop between gears. Like if I shift 1st to 2nd at 6500 how much do the rpms drop to when 2nd gear engages? 2nd to 3rd?
Old Jul 29, 2007 | 03:14 PM
performabuilt's Avatar
LS1Tech Sponsor
Actually that would be a little hard to determine with a stall. You can use the ratios of the trans and percentage of difference if there was no stall slip or if the converter was locked.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
