Yank SS converter
Old Nov 19, 2002 | 06:06 PM
wm_sorg's Avatar
Default Yank SS converter
Ok So I have decided to get a Yank SS converter for my project. Unfortunately, I can not get ahold of Mike so I was hoping a few you guys could answer a few questions.
1. Is the converter gaining stall from reverse angle blades or is it smaller than the stock unit?
2. What size is it 10" 12", etc?
3. How is the customer service?
Any other thoughts would be greatly appreciated.
BILL
Old Nov 19, 2002 | 06:29 PM
Colonel's Avatar
Default Re: Yank SS converter
It's alot smaller than stock. I believe stock is 298mm (would be called a 12") and the SS line is only 245mm (would be called a 9.5".)
Look at the weight difference! Stock is 52 lbs where as the SS converters are only 29 lbs. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
BTW, all of this information and MUCH more is on on Yank's website. Check it out sometime.
JTM's Avatar
JTM
It is a 9.5" converter.
Old Nov 19, 2002 | 06:30 PM
turbo's Avatar
I can tell you about his customer service. The others I dont know.
The only problem I ever had with Mike is getting a hold of him. Hes very busy. Whenever I talked to him he took the time to answer questions. His converters are very good. I had a special project at one time and needed a converter very fast and he got it to me when I needed it.
Casey
<small>[ November 19, 2002, 06:31 PM: Message edited by: turbo ]</small>
Old Nov 20, 2002 | 01:59 PM
Justin99TA's Avatar
I called and talked to mike about one on tuesday. Im going to get a SS3600 I think. If its anything like my old ST <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Justin
