shifter shaft on 4l80e
Old Aug 9, 2007 | 03:43 PM
FRUSTRATED T/A's Avatar
Default shifter shaft on 4l80e
the 4l80e shifter shaft coming out of the 4l80e is much longer then the 4l60e how do i switch them. or can i somehow use the 80e braket or something i saw in the 60e to 80e sticky.
Old Aug 9, 2007 | 09:02 PM
RamAir02TA77's Avatar
I think you just need the bracket from the 4l60e I also got this info by reading that writeup... If you have an older model 4l80e I think maybe 99 and down you might need a 99+ shifter linkage maybe this will help somewhat...
Old Aug 10, 2007 | 05:31 AM
ttcamaro's Avatar
yes get the 60 bracket, then buy the lever with a 10mm ball on the end and any cable from a 94+ car should work fine
Old Aug 10, 2007 | 08:09 AM
FLT's Avatar
FLT
There's two different length selector shafts available for the 4L80E, you need the short one. If you need the part # or want to purchase the correct one for your application feel free to give Vince or myself a call at the shop.
