No Manual Shift w/4L60E?
Old Aug 16, 2007 | 07:51 PM
Asmodeus's Avatar
Manually upshifting a 4L60E will make your car slower in the 1/4 mile. It takes 1.5 seconds for the car to make the shift when you do it youself, and less than a second when it can predict the shift.
Old Aug 16, 2007 | 10:16 PM
5_02ls1's Avatar
the 4l60e in stock form will not shift manually....it will hit the revlimiter everytime......if you wanna shift it manually have a transgo shift kit installed.....
and you did not hurt anything....what you experienced is normal.......
Old Aug 16, 2007 | 10:26 PM
Black99TransAm's Avatar
thats funny because i can manually shift my car every shift without hitting the rev limiter.. and thats even with the spray. STOCK 4L60E with 66k miles on it
Old Aug 16, 2007 | 10:32 PM
CaMaRo67RS355's Avatar
wanna act like a 6 speed get a 6 speed. it puts wear and tear on ur transmission faster. its not like IHRA and NHRA drag cars theres arent true automatics and are built very different from the 4L60E leave it in drive and go.
Old Aug 16, 2007 | 10:59 PM
Smokin00WS6's Avatar
The paddle shifting on my Vette is so completely different than powershifting a 4 speed automatic tranny. Power shifting does hurt the tranny and the components, its not made for doing that unless you build it up and put special kits on them. Believe what you want to believe but I dont think its a good thing.
Old Aug 17, 2007 | 12:47 AM
WannaBcamaroguy's Avatar
How about down shifting at low speeds that wouldnt hurt the tranny would it?
Old Aug 17, 2007 | 12:51 AM
still puts strain on it
Old Aug 17, 2007 | 01:25 AM
Fbodynightmare's Avatar
Default ??
Get a 3 speed turbo 350 or 400 with Manual Valvebody can't go wrong.
Old Aug 17, 2007 | 11:26 AM
blueeyeddevil141's Avatar
Upshifting won't blow your **** up, downshifting it is bad, even for a manual.
Old Aug 17, 2007 | 12:14 PM
RamAir02TA77's Avatar
Is downshifting into reverse from 20mph and putting it to the floor bad? Jk my buddy does that in his 4l80e truck every once in awhile. I have heard different things about manual shifting trannies. I never did in my car but my truck (700r4) sometimes I manual downshift when going down hills to save the brakes there seems to be no effects so far.
Old Aug 17, 2007 | 02:01 PM
ss dave's Avatar
I have a Hurst Dual Gate with Compushift controller that I use to manually shift my 4l60e Performabuilt with a Yank. Can't help but roast the tires all the way to 7K.
