Running Tractor Fluid?
Old Aug 16, 2007 | 11:26 AM
dpw41285's Avatar
Default Running Tractor Fluid?
What kind?
Are you running a mixture?
What did it do to the : Shifts , Temps and Stall Speed
How long have you used it and any problems?
Im sure im not the only one with the questions, I know madman, rossler and alot of high po guys are running it. I am thinking about running John deer hy-gard un-less you could recommend something at tractor supply thats equvilant or better!
Old Aug 16, 2007 | 03:16 PM
jakeshoe's Avatar
I mix the tractor fluid with a bit of Dexron for color. I use the SuperTech (Wal-Mart) brand. Look at the chart on the container, it cross-references to the JD fluid and others.
I haven't been able to tell any difference except maybe a slightly firmer cold shift.
My only complaint with it, is the smell, it has less odor than Dexron when new, but for me it is hard to tell if it has a burnt smell or not. Harder to diagnose the fluid in other words.
It is good stuff, it has a higher temp rating than Dexron, and it seems to work well.
Old Aug 16, 2007 | 04:42 PM
dpw41285's Avatar
what ratio did you mix? and you didnt see a change in stall speed
Old Aug 16, 2007 | 05:54 PM
jakeshoe's Avatar
I haven't seen a change in stall speed. If there is a change it would be while it is cold or probably very small difference.
I use about 9-10 qts of tractor fluid and 2-3 qts of ATF on a dry fill.
I buy the tractor fluid by the 5 gallon bucket so I pour a couple of qts of ATF in the pan/converter and then fill with tractor fluid.
Old Aug 17, 2007 | 01:10 PM
dpw41285's Avatar
im sure your not the only one using it
