Question about A604/A606 tranny
Old Aug 16, 2007 | 07:38 PM
BamBam03's Avatar
Default Question about A604 tranny
I have a question regarding a 2000 Chrysler Cirrus regarding an automatic transmission.
The car will go into second gear and then not shift out of 2nd while reaching a top speed of 30-35 with the RPMs staying at around 5000. It will shift into gears while parked, and their seems to be nothing wrong with the engine, but the car will not go over 35MPH and does not shift out of 2nd gear. The check engine light is also on. This car only has 20K on it . Any help would be helpful. Thank You.
Old Aug 16, 2007 | 07:45 PM
performabuilt's Avatar
LS1Tech Sponsor
You need to have it scanned nout and output speed sensors are comon issues with these
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 16, 2007 | 08:57 PM
Gilbert@Ace Racing's Avatar
Chrysler engineered that transmission to have a feature called "Limp in". Basically it will lock down in 2nd gear when there is a fault detected. Those utilize an input and output speed sensor... they are notorious for failing.
Usually if the condition is intermittant the transmission will try to upshift at least one time after the ignition key has been cycled. If it goes into Limp In immediately then the problem can be considered a hard fault and should be easily diagnosed.
It is not likely at that low mileage that there is an internal problem.
Good Luck.
g
Old Aug 16, 2007 | 09:54 PM
Montec's Avatar
Get it scanned.
Old Aug 16, 2007 | 10:02 PM
WE TODD DID's Avatar
I wouldn't bet on the oss, if the speedo is working. None the less, it needs to be scanned. Check your fuses first. If there is no power to the solenoid pack, it'll hard fault with codes.
Old Aug 16, 2007 | 10:07 PM
LS1Tech Sponsor
Yes again get it scanned, As for the vss the chrysler front wheel drive have and input speed sensor and output speed sensor and then some have a vss sensor they are and odd systemone of a kind actually.
__________________
Call 888-744-6542
