Want to get a converter. HELP!!!
Old Aug 17, 2007 | 09:31 AM
iamnitrox's Avatar
Default Want to get a converter. HELP!!!
Seems like everyone on here is running a 3000-3500 stall converter. Let me know, how does this act on the street? I am dying to get some real life feedback about high stall converters on the street. I want my times to get better, but Is the cost of having a stall converter too high for a car I like to drive and take on road trips?
Old Aug 17, 2007 | 10:03 AM
'00_Z's Avatar
Most 3000-3600 converters are considered pretty mild. There are many choices btwn stall ratios, which determine how loose or tight a converter is. I haven't put mine in as its a 3000 and I've decided to go bigger. You will notice a difference around town more so than on the highway, from what I've gathered and I've done alot of research. I've only had one car that I had a bigger converter in but it was a big block Olds and a totally different animal, so I can't compare the two. I know everybody says the same thing, but use the search(when it works) and the stickies, you will find alot of useful info.
Old Aug 17, 2007 | 10:29 AM
performabuilt's Avatar
LS1Tech Sponsor
Depends alot on the converter, Tighter converters like ours are known to be give a good performance increase while retaiing excellent drivablility. Now the "looser" converters while they can give you more bite right off the line floored generally have major effect on lower speed fuel efficency. Either will give the same highway efficency, Butin simple a tight performance converter in the 3000 to 3500 range will provide enough fun to easily offset any small loss in low end efficency.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 17, 2007 | 04:57 PM
performabuilt2's Avatar
LS1Tech Sponsor
of course I have a Performabuilt 3000 in my car 01 t/a and it is really nice doesnt feel to much different than stock just normal driving but when you flat foot it you can tell and it really helps the car off the line
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
