th400 swap???
Old Aug 20, 2007 | 05:00 PM
bowtierodder's Avatar
Default th400 swap???
ok i tried the sticky and a the search but just came up with more questions than answers. so here goes.....
i have a th400 tranny w/ converter for an ls1 (long snout)
i have a 98 flex plate (flat style), will this combo just bolt up or are spacers or anything else required
also it used to be an m6, do i have to take the pilot bearing out of the back of the crank??????
and im using the bmr crossmember, what trans mount do i need?
thank everyone
Old Aug 20, 2007 | 08:07 PM
Gilbert@Ace Racing's Avatar
Replied to your P.M.!
g
Old Aug 21, 2007 | 07:58 AM
408z28's Avatar
1. Leave the pilot bearing...no need to remove it.
2. Use your stock 6sp. crossmember w/ th400 mount
Old Aug 27, 2007 | 09:52 PM
blkbird_WS-6's Avatar
I used the tranny mount off of the M6 when I had the TH 400 in my car. You have a PM by the way.
