New tranny looses 3rd and 4th
Old Aug 21, 2007 | 01:41 AM
millerpa's Avatar
Unhappy New tranny looses 3rd and 4th
Just recently got new tranny in my camaro Two weeks before leaving for college. Mild Built 4L60E, not more than 500 miles on it. Was on high way (65mph) and in 4th and every time it down shifted to third it slipped and never would grab. Next i new no 3rd and 4th. just moved to college with a broken car and is my only transportaion. Dont know people yet here and having hard time figuring out what do do.
any help would be much appreciated
Old Aug 21, 2007 | 07:28 AM
FLT's Avatar
FLT
It would be best for you to get in contact with your builder. See what options you have with them as far as warranty and obviously what they are willing to do to correct this situation. A loss of 3-4 is normally an internal issue. Are you getting any codes? How does the fluid look and is it full?
Old Aug 21, 2007 | 09:27 AM
performabuilt's Avatar
LS1Tech Sponsor
I would agree is 3-4 has been working and your neutraling where the shift should be its likley and internal issue with th 3-4 clutch. You should contact the builder for warranty if there was one. Sorry to hear of your miss fortune.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 21, 2007 | 08:43 PM
millerpa's Avatar
I talked to my builder today and he really did not help me. The tranny fluid does not appear or smell. The magnet in the pan is not all gummed up with 3-4 clutch material. hooked a scanner up to check all of my shift silinoids they all worked as far as i could tell. checked servo seals all where fine.
only thing that my biuder was thinking was previos tranny did not have secong gear, he thought cuz i didnt flush stock converter and stuck a stock one in the new tranny possibly stuff came out of old inverter and debree got in the valve body or something?
Old Aug 21, 2007 | 08:55 PM
LS1Tech Sponsor
Sorry the builder is not willing to be helpfull . Though a valve body issue could cause a no shift to third what you seem to be describing is a neutral or slipping where third gear should be , Its unfortunate but sounds like something has happened to the 3-4 clutch.
__________________
Call 888-744-6542
Old Aug 21, 2007 | 10:15 PM
millerpa's Avatar
ok well i guess ill pull the tranny and check out the clutches, if it was the clutches shouldnt there be stuff on the magenet and shouldnt the fluid smell burnt. just curious before i pull my tranny?
Thanks
Old Aug 21, 2007 | 10:34 PM
LS1Tech Sponsor
Some times but there are issues that may not result in that broken drum would be one possibility . let me know what you find I am always interested in a failure and the reason why and let me know if I can help you in any way .
__________________
Call 888-744-6542
Old Aug 22, 2007 | 01:20 PM
millerpa's Avatar
ok thanks, ill keep you poste. at college for autobody, but the mechanics teacher is going to help me diagnos it to get me back on the road
Thanks again
Old Aug 22, 2007 | 01:21 PM
millerpa's Avatar
ok thanks, ill keep you posted. at college for autobody, but the mechanics teacher is going to help me diagnos it to get me back on the road
Thanks again
Old Aug 23, 2007 | 09:08 AM
millerpa's Avatar
So i drove my car the other day and usually i have to drive around in second., but i accidentaly put it in drive and did not know. some how it shifted into third and fourth that day. thinking some thing in the valve body was plugged and kicked it out of the system so it worked fine for now, going to get tranny flushed to try to get it all out. is that possible? it was really wierd
