Vigilante 5 clutch setup info
looking for info on this type of stall/clutch set up...
i guess what kind of stall do i need for a 800+ rwhp 700 + rwtq car in a 4l80e in a 3800lb car
the power will be coming from a 355 ysi set up
i have been told the 5 clutch set up is needed for cars over 700 level
the car will be driven on the street as well, i am looking at a 3200 stall to start with,,
Keep in mind the multi disc units do often rattle a bit at idle.
Lockup will not generally help et/mph unless it is a turbo car (which often seem to like the additional load of a locked converter) or unless you are overgeared & need to keep off the rev limiter at the end of the track due to slippage.
What kind of stall are we talking here ?....why do sssooooo many people talk about this and the mpr they pick up ?????
