Speed Sensor
Any help would MUCH be appreciated.
If this is the problem, leave the speedo disconnected until you have the trans calibrated. With the trans sorted you will need to rough calibrate the speedo with the rear wheels on jackstands. Get it close enough that the trans shifts properly (i.e. I ran my Auto Meter speedo calibration counter up to 2500 pulses). Then you can go out on the street and do a proper 2 mile calibration.
Worth a shot anyway.
