What to re-stall a PYE3400 to?
Old May 26, 2003 | 10:42 PM
cne411's Avatar
Default What to re-stall a PYE3400 to?
I pulled out my PYE3400 this weekend so I can send it back to Yank for a restall. I'm not sure what I want to restall it to. My chioces look like PYE3600, SY3500 or SY4000, I think this is right because they all use a 258mm case. The PYE3400 worked great with 2.73 gears but when I put the Moser 12 bollt in with 3.55 gears it was way too tight. I thought I wanted a SY3500 till I put in a TCI SSF3500 (I am borrowing the SSF until I get my converter back) now I think I want a SY4000.
My question is will a SY4000 work well on a daily driver, will the SY3500 be looser that the SSF3500? My goals are to have a good driver that is not too loose, great from a roll, and easy to launch.
Thanks for your time.
Old May 27, 2003 | 10:06 PM
Ragtop 99's Avatar
Default Re: What to re-stall a PYE3400 to?
The SY 3500 best meets that description. If he can't do that, the PYE 3600 is a noticable step up from the PYE 3400, despite only 200 rpm in stall.
Old May 27, 2003 | 11:48 PM
cne411's Avatar
Thats what I was thinking, I just don't want to go too small and change it again.
