4L60E not going into 4th gear
Old Aug 29, 2007 | 03:14 AM
JGM's LS1's Avatar
Default 4L60E not going into 4th gear
I own a auto 98 Z28, I was on the roadthe other day when my 4th gear just went into neutral in OD. I had to switch it to D in order to get to my shop. There I checked my trans oil and it wasnt a burnt smell. The next day i changed my trans oil filter and put new oil. My car still doesnt move in OD unless i give it a little gas. I think my trans might be going out the car just reached 100k miles. Can anyone help me out!
Old Aug 29, 2007 | 05:20 AM
FLT's Avatar
FLT
If it is totally in neutral in the OD position you have an input sprag failure happening. It is going to get worse get it fixed Give me a call if you need some help with that. Vince
