How do I mate LQ4 to a TH350?
Old Aug 30, 2007 | 03:47 PM
team39763's Avatar
Default How do I mate LQ4 to a TH350?
I believe my LQ4 is a 2004. I bought the GM crank spacer. I'm using a B&M TH350 converter. But when I tighten down the bellhousing bolts, the converter gets jammed up. Yes, I put it in correctly, I slowly rotated it and felt 3 engagements/clicks. It goes on smoothly, but when I tighten it that last 1/8" it jams up the converter. I just cracked the bellhousing a minute ago when I tightened it that last 1/8". It was supported by a jack. What am I doing wrong? Any help or advice would be greatly appreciated. Thanks.
Old Aug 30, 2007 | 04:29 PM
408z28's Avatar
you dont need a crank spacer, you need a pilot adapter.
Old Aug 30, 2007 | 04:38 PM
team39763's Avatar
I'm pretty sure that's what I had, but someone referred to it as a crank spacer, so that's what I called it. Thanks.
