just got trans rebuilt not working right!!! HELP
Old Sep 1, 2007 | 09:09 PM
93lt1n00b's Avatar
Default just got trans rebuilt not working right!!! HELP
ok i just had my trans rebuilt because it lost 3rd and 4th well i got it all back in and it doesnt shift untill i take my foot off the gass and somtimes doesnt downshift what could be causing this. IM worried when i put it back in that the cable that goes from the Trottle body to the trans was put in wrong please somone help
Old Sep 1, 2007 | 09:24 PM
performabuilt's Avatar
LS1Tech Sponsor
Could be several things , valve body sticking etc. But first I would ajust the TV cable. This link should give you a good idea of how to do it , http://www.tvmadeez.com/article/index.html
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 1, 2007 | 09:29 PM
FLT's Avatar
FLT
Did you adjust the TV cable when you installed the transmission?
Old Sep 1, 2007 | 09:40 PM
93lt1n00b's Avatar
no i didnt do anything i just bolted it back up i know nothing about transmissions could you explaine
Old Sep 1, 2007 | 10:49 PM
93lt1n00b's Avatar
anyone?
Old Sep 1, 2007 | 11:02 PM
FLT's Avatar
FLT
Any time you install a 700r4 you need to make sure that the cable is adjusted correctly. This cable is what controls the transmissions line pressure, shift points, and also the downshift function of the transmission. The link that Frank provided in the above post from Bowtie overdrives is one that you should read. It gives you the correct information for properly adjusting the tv cable on your car. This is the first thing that you should address on your car. I believe that your cable is either out of adjustment or is in need of replacement. You might have an internal issue but this is the first thing to address.
