Trans builders help, 4L60E build one last time
Now I don't have the trans apart yet, but I'm assuming the clutch is out of it. Not sure if its burnt out or something broke in the circuit (piston, springs, snap ring). It went out fast, it starting slipping slightly, 10 mins later no 3 or 4 gears. It was a 8 clutch alto red with kolene steels.
I installed a servo release check valve, could this screw things up if the feed holes are the wrong sizes?
I did have a problem trying to install the transgo hi-rev springs, I couldn't get the 3-4 spring retainer to stay together. So I put the stock springs back in.
this will the the 4th time I have this trans out of the truck, this will be the last time, next time its 4L80E time.
2002 4x4 4L60E upgraded to
5 pinion planets
hardened input shaft, sleeve input drum
carbon fibre stock width band
hardened beast sungear shell
BW 27 element sprag
corvette servo
hardened output shaft
Servo release check valve
trango HD set to mild
alumium acculator pistons
Alto clutches
Thanks
The feed holes are drilled to .093" I think. The instructions that came with the servo check valve said to drill them to .120 or something like that. I stuck with the Transgo instructions for fear of hard shifting, and breaking band. (I've already ripped the band anchor off the pin once, with this trans)
I don't remember drilling any holes in the valve.
Does this valve help, or should I just leave it out.
Thanks
