TH 400 install from an m-6?????????
Old Aug 5, 2008 | 07:05 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Originally Posted by 99Ls1fever
Thanks Man
How is your sixty foot???
It's only been a 1.55 on a 125 shot but the new trans, converter and some suspension should drop it some.
Originally Posted by 69TA
If you ran the TCI flexplate.
Wouldn't the pilot on the SBC turbo 400 converter still
be off or not the same for use on an LS1?
It won't seat in the flexplate but they make a spacer to solve the problem. I didn't run it with my old converter but PTC custom built my new nitrous one specific to my setup(including a extended pilot).
Old Aug 12, 2008 | 11:28 PM
99Ls1fever's Avatar
How many of you guys are running the th 400 and what are your track times? my buddy went to wyo tech and tells me I would run slower if I ran a th 400? is this true from my M6? Cause I want the power but definatley dont want to go slower......
Old Aug 15, 2008 | 02:26 PM
sidewayz28's Avatar
yo buddys a fool... your th400 will eat up more power, yes... but your will be 10x more consistent than any 6 speed...
Old Aug 15, 2008 | 03:26 PM
yellabella's Avatar
second that nobody can shift better than an auto
Old Aug 15, 2008 | 03:28 PM
yellabella's Avatar
I also have a few questions what are all the nessacary parts to complete the install from m-6 to T-400 I know I know theres a sticky but its so spread out. I want to do it the right way
Old Aug 18, 2008 | 02:43 PM
99Ls1fever's Avatar
So, it wont eat up ET. right???
Old Aug 19, 2008 | 12:48 AM
X.Modesto's Avatar
OK can someone make a list here, am thinking of doing the same thing! Here is my attempt somebody correct me if am wrong or add anything that is missing.
1. New or Used Flexplate,
2. LSx specific torque converter (which means longer pilot bearing?)
3. Any th400 or th350, If using th350 get the one with the 9 inch tailshaft so you can resuse you stock driveshaft.
4. New chassis mounted torque arm
5. New Shifter and maybe console.
6. New big tranny oil cooler
7. Some speedo and abs light removal mods
Anything else guys?
Old Aug 19, 2008 | 06:47 AM
Z28/2002's Avatar
The link dlove posted is very helpful
https://ls1tech.com/forums/automatic-transmission/815618-th350-th400-frequently-asked-questions.html
Old Aug 19, 2008 | 12:33 PM
sidewayz28's Avatar
your ET will drop and im guessing along with a few MPH's...
Old Aug 19, 2008 | 07:45 PM
Blown 98 Z's Avatar
I have a thread somewhere around here....try a search T-56 to TH-400
Don
Old Aug 20, 2008 | 03:43 PM
99Ls1fever's Avatar
Don
You are out of colorado right man, I think I met you at pinks all out...
Old Aug 20, 2008 | 07:43 PM
  #32
Blown 98 Z's Avatar
Quick 98 ring a bell?
Old Aug 20, 2008 | 09:45 PM
  #33
99Ls1fever's Avatar
O yes you sexy devil I met you at pinks i was with Chad in the Jeep when we drove up and met you, I work at bandimere for the past 7 years and knew that car was fast. I just needed to match a face to the car
So you think there would be real no ET loss switching to a TH 400 application cause people I have be around tell me it is not worth it unless i am using a trans brake....?
Old Aug 20, 2008 | 10:46 PM
  #34
blkbird_WS-6's Avatar
When I had a Th400 in my TA, it slowed down .1-.2 tenths and lost 4-5mph in the 1/8 mile. This was launching off the foot brake. I did read somewhere on this forum that using a transbrake would gain maybe .2-.3 But I can't support that with any of my experience.
Old Aug 21, 2008 | 12:14 AM
  #35
99Ls1fever's Avatar
Thanks man thats what I was woundering...
