Park?
Old Sep 15, 2007 | 06:24 PM
mySlowLt1's Avatar
Default Park?
Should the wheels move while the car is in park? I have a new tranny and have tried all of the selections and it moves in everyone. Now i have not put fluid in it but i dont think that would change anything. What do you guys think?
Old Sep 15, 2007 | 07:08 PM
performabuilt's Avatar
LS1Tech Sponsor
Park is a purley mechanical function , Check linkage and without linkage hooked rotate the shifter peice on trans fully clock wise and then try to turn drive shaft. Should turn a short distance the stop.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 16, 2007 | 09:36 AM
FLT's Avatar
FLT
Forget what the wheels are doing. You need to look at the drive shaft. If the drive shaft still turns in park then you have an issue. The wheels depending on what type of rear end or condition, might still turn but in opposite directions.
Old Sep 16, 2007 | 11:24 AM
mySlowLt1's Avatar
Ok guys thanks, I guess i should have elaborated i was spinning the DS by hand with the tranny in park. I took the pan off and it works great now
Thanks
