Th350
Old Sep 17, 2007 | 09:25 PM
josh2002-ws6's Avatar
Default Th350
Can anyone tell me the pro's and con's of switching from a M6 to a TH350. I plan on running nitous after this winter with the new heads and cam. I would like to be in the low 10's to high 9's. Will the TH350 stand up to what I need and want or should I look at a differant auto tranny?
Old Sep 17, 2007 | 09:42 PM
8a8mfh's Avatar
I don't know but you can throw a stock rebuild kit and a 4L80E direct drum+sprag ($50-100 at a trans hardpart supplier) in a th400 and it'll hold the power IMO. The th350 MIGHT with a hardened intermediate race or an expensive custom direct drum.
And some other tweaks here and there.
Old Sep 17, 2007 | 10:27 PM
performabuilt's Avatar
LS1Tech Sponsor
I have said this before a TH350 is not that much stronger than a 4L60E pariculary if your breaking hard parts , if you saw inside one you might be amazed just how similar they are. as for how different well much higher first ratio , much lower final ratio. Drivability will suffer as far a fuel efficency and general engine wear. More cruising RPM equals more wear. Why not go buILt 4L60E or better yet 4L80E
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 17, 2007 | 10:35 PM
Default 4l80e
Where is a good place to get a 4L80E?
Old Sep 17, 2007 | 10:39 PM
LS1Tech Sponsor
There are several sponsors on here who offer them we do not at presnet but will in about a month when we are set up in our new larger building. I would PM a few of the Trans sponsors on here right now.
__________________
Call 888-744-6542
Old Sep 17, 2007 | 11:03 PM
Cool thank you.
Old Sep 17, 2007 | 11:19 PM
LS1Tech Sponsor
Your welcome!
__________________
Call 888-744-6542
