PG Driveshaft
Old Sep 25, 2007 | 12:32 AM
Guacamayo's Avatar
Default PG Driveshaft
Just ordered a powerglide tranny to work with my 346 ci on my 00 black Z28. I was wondering if any of you has the measurements of the driveshaft, I'll appreciate them a lot, thanks.
Old Sep 25, 2007 | 01:18 AM
8a8mfh's Avatar
No one has it. I'd assume if you're using a PG you must have a race only car, you shouldn't be using the stock rear. A lot of things like this effect the driveshaft length.
You need to get everything bolted up and measure, you'd be pretty upset if someone gave you a length here and it was too short and you ended up needing to buy another one.
Old Sep 25, 2007 | 08:21 AM
Guacamayo's Avatar
Yes I will get the measurements but wanted to know the lenght of it to compare it. Im bolting it to my stock rearend for now but later I'll bolt it to a ford 9. Thanks anyways and if someone's got the measurements on a 10 bolt or a Ford 9 Ill appreciate it.
Old Sep 25, 2007 | 10:25 PM
4thgenz's Avatar
just measured mine tonite. from stock 4L60E to stock 10 bolt.... 41 3/8"
that is from center of u joint to center of u joint. hope this helps in any way.
but like 8a8*** says....dont use this as your measurement for your car. the glide will be a different length.
