Case differences
Old Sep 25, 2007 | 09:02 AM
Montec's Avatar
Default Case differences
Ok are there any case differences between 93-97 ONE peice 4l60e cases.
What im trying to find out is if the PWM cases and the non PWM cases are physically the same and that the only differences for pwm are the pump, valvebody, separator plate, and computer. So you could swap everything from a PWM case over to a NON pwm case and the trans will work?
Old Sep 25, 2007 | 09:07 AM
FLT's Avatar
FLT
YES!!!! The only differences that I have seen would be bosses on the linkage side of the case if a neutral switch was being used, shifter braket mounts and also the inspection cover. Vince
Old Sep 25, 2007 | 09:17 AM
performabuilt's Avatar
LS1Tech Sponsor
Agreed with the exception of the bosses for the PNDL switch and the 2 K CASE and non K case styles They will interchange.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 25, 2007 | 11:24 AM
Montec's Avatar
awesome. Thanks guys.
Old Sep 25, 2007 | 12:04 PM
LS1Tech Sponsor
You are always welcome
__________________
Call 888-744-6542
