1st gear gone?
Old Sep 25, 2007 | 02:02 PM
rob scott's Avatar
Default 1st gear gone?
ok i just installed headers and a 3600 yank and when i stop at a red light the car wont move till 3400 and then it wants to fly. but its very slow moving till about 20mph then its a diff story. when its cold it shifts but hot it wants to lay. i had the stall in for about 4 months and haven't had this problem till the headers went in, so could it be in need for a tune?
Old Sep 25, 2007 | 02:42 PM
performabuilt's Avatar
LS1Tech Sponsor
First I would scan for codes and I would inspect the area around the headers for burnt or broken wires
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 25, 2007 | 07:57 PM
rob scott's Avatar
ok now would a auto zone scanner find them? it will go into first if i leave it in 3rd gear or pull it down.
Old Sep 27, 2007 | 10:32 AM
LS1Tech Sponsor
I would try the scan first and yes the autozone scanner will check for codes
__________________
Call 888-744-6542
Old Sep 27, 2007 | 11:07 AM
rob scott's Avatar
the scanners said low volts to the 02's that was it
Old Sep 27, 2007 | 11:50 AM
LS1Tech Sponsor
Check fuses and wires all that stuff is in the trans wiring harness.
__________________
Call 888-744-6542
