Need some help! Car won't go doesn't go forward anymore
Still kind of new to this thing. 3400 Fuddle HPS stall. Had no issues at all with it on a 500 mile trek....until I got off the interstate. Starting hearing a cracking sound type sound and when I came to a full stop the car did not want to move forward. Did that the entire rest of the way home (about 25 more miles) anytime I came to stop. Reverse works perfect. But going into drive is a no joy now.
Please help!! I leave Friday to see my fiance and if the car needs to go some place for a rebuild or anything I want to do it tomorrow so it'll be done before I get back. Or else I'm literally screwed since I have no DD.
In all honesty, not being a smartass or anything price range is $200 to $2000.
If you want a more accurate guess at least list miles, trans mods, trans service history, average driving style, previous problems, original trans or not.
-Car has 45k (literally just turned it)
-Trans mods are the 3400 stall, tranny cooler (placed underneath the airdam basically below the fans
-Has always been serviced and filter changed. When we put the stall in, 02WS6TA was amazed that there was ZERO metal in the pan
-No problems at all until literally an hour ago
-Original tranny yes
-Driving style, I don't WOT the hell out of the thing and actually drive it pretty normal. Seldom even seen a race and never touched a drag strip
LS1Tech Sponsor
If its just really hard to go when this happens you are probably seting limp mode , Third gear starts from the stall and code po757 should acompanie it , A vey comon condition if this is the case after you turn the car off things should return to normal for a bit, If this is the case have the test for the code P0757 removed and all will be good again, If not then you likely need a trans, Scanning is the first priority,
__________________
yes those scanner can check for codes and yes sometimes this condition dosent show up for a while
I prefer to tell people to expect the worst, that way it's a huge relief if it actually is something easy.
Get someones hopes up that it's an easy fix and find out it's not, it's a disappointment.
LS1Tech Sponsor
Understand but hey a little hope can make the day better even if there is a crash at the end lol
__________________
Originally Posted by BigT2002
Very true and I honestly appreciate that man, I really do. I keep the worst in the back of my head...but with the issues shes given me over the last two days, I think I deserve a break lol.
