Factory filled units
Old Oct 2, 2007 | 10:38 AM
robertbartsch's Avatar
Default Factory filled units
If your auto tranny does not have a filler tube (e.g., Ford, BMW) is there a filler plug on the side of the case where you can add/change fliud?
I would assume this is the case since the factory filled units have a stamped tranny pan with standard bolts that is used to access the valve body, drum bands, filter, etc.
Thanks...
Old Oct 2, 2007 | 10:48 AM
performabuilt's Avatar
LS1Tech Sponsor
BMW has the fill plug one the drivers side rear just above the pan rail
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 2, 2007 | 11:44 AM
OK, thanks ...
Where would you buy synthetic tranny fliud?
Old Oct 2, 2007 | 12:39 PM
LS1Tech Sponsor
Any auozone would have it, We get ours in 5 gallon cans but I have no idea where it comes from
__________________
Call 888-744-6542
