How does a 4l60 1-2 Accumulator operate?
Does the fluid enter from the bottom of the 1-2 bore pushing piston towords the seperator plate and transmission case? If that is correct then putting the springs between the piston and the plate would that soften up the apply? And if you put the springs in the 1-2 housing wouldn't you basicly be doing away with the accumulator function, much like you do when you put the 3-4accumulator spring inside the case?
