Best auto for the street but will hold up to the track?
Old Jun 10, 2003 | 11:36 PM
Dragaholic's Avatar
9 Second Club NA
Default Best auto for the street but will hold up to the track?
Looking into converting my M6 SS to an auto and wanted to be sure that I make the right choice before I go blow 2 or 3 grand! I hear that the 200R4 is a good tranny as far as what Im looking for. The car is a daily driver and I would like an auto to compliment that. The car hasnt been to the track since it was stock! I have done so much to it and still havent really had the desire to take it to the track. I dont want to because I dont have the gear, tires, or driveline to do so. The only thing that I have touched as far as driveline goes, is the entire clutch system. But even that isnt going to get my what I want. Anyhow, Id like to get an auto. that will hold up at the track but is still streetable. Im pretty sure that I want it to have overdrive if I want it to be streetable, right? Dont really have a budget, but Id like to know what my options are. Thanks
Old Jun 10, 2003 | 11:50 PM
Z-Rated's Avatar
Default Re: Best auto for the street but will hold up to the track?
I know this is off subject, but what color is your car? and what kind of rims do you have?
Old Jun 11, 2003 | 05:41 PM
Black Sunshine/ 00SS's Avatar
I just went to a 400T, so I could start worrying about something else. You wont likely have problems with the 400. It will handle anything you can throw at it. If you miss the OD, then get a GV overdrive, and you are set. Good luck.
Old Jun 11, 2003 | 06:29 PM
Linear Velocity's Avatar
There's no way you'll need a th400 for the kind of power you are putting out, plus they are heavy and have lots of drivetrain loss, add a GVOD unit to it you're looking at additional 100 lbs 2,400 bucks. 200-4R would be your best bet, even better would be a built 4L60E. 200-4R's are awesome but can shift a little firm on the street, I'm going with a 200-4R but I'm putting almost 500 rwhp out and want the transbrake for the hard launches.
Old Jun 11, 2003 | 07:17 PM
Ragtop 99's Avatar
Are you looking for manual shift or a true automatic? You can get a 4L60e that will hold up to H&C car if you want a true automatic.
Old Jun 11, 2003 | 07:29 PM
Michael Ozorowsky's Avatar
I think I may need a new tranny. Would a built 4L60E handle 500+RWHP???
