A4's: Do you use
Old Jan 11, 2003 | 01:05 PM
Colonel's Avatar
Default Re: A4's: Do you use
It's not an '01 and up problem. My '00 reached higher rpms on the 2-3 shift when in D. If I had the shift point set too close to the rev limiter, I hit it in D but not in OD.
Maybe the reason the converter seems to lock up harder in D is because it's actually locking up in D rather than shifting to OD and then locking up. It would feel harder with a 1:1 gear than a .7:1.
Old Jan 11, 2003 | 01:41 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong>
Maybe the reason the converter seems to lock up harder in D is because it's actually locking up in D rather than shifting to OD and then locking up. It would feel harder with a 1:1 gear than a .7:1. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is a very good point <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I had not considered this before. That probably is the reason for the harder/stronger feeling lockup...
Old Jan 11, 2003 | 03:45 PM
sited12's Avatar
Was just going to mention that OD 4th gear is .7 and D 4th gear is 1 so with the better gear ratio when in D wouldnt you go faster. Maybe it revs higher because it is spinning faster in D. More reps than in OD.
Old Jan 12, 2003 | 08:44 AM
Colonel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sited12:
<strong> Was just going to mention that OD 4th gear is .7 and D 4th gear is 1 so with the better gear ratio when in D wouldnt you go faster. Maybe it revs higher because it is spinning faster in D. More reps than in OD. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You're confused. It doesn't matter if the selector is in D or OD as to what the ratio will be when the tranny is in a given gear. What I mean is, say you have it in OD and you start off from a stop...you're in 1st gear which has a ratio of 3.06:1. If you start off in D it is the same thing...1st gear is 3.06:1. Same goes for when the tranny shifts into second...the ratio is 1.62:1 regardless to if the selector is in 2nd, D, or OD. Likewise, 3rd is always 1:1 regardless of where the shifter is.
