Question about my TH350
Old Nov 22, 2007 | 03:09 PM
cryptnosis's Avatar
Default Question about my TH350
I am tryin to sale my TH350, converter and driveshaft that i installed on my 99 LS1, the guy who is interested in it has a 1st gen, and doesnt know if the converter will work for it. So my questions are will my verter work for a gen 1??
next question , is the th400 driveshaft different lengths from the th350?
last question, will the vss sensor adaptor i had for my th350 work for a th400?
i am pretty sure it will since it measures the drive shaft spends.
Old Nov 22, 2007 | 04:11 PM
98turbls1's Avatar
The converter will work without any problems if it's made for a sbc... If it was made for a LSX engine I believe you will have to alter the snout...
Is he running an electric speedometer?? If no then he'll probably have to get a different (manual) VSS...
Old Nov 22, 2007 | 09:42 PM
dlove's Avatar
see this thread https://ls1tech.com/forums/automatic-transmission/815618-th350-th400-frequently-asked-questions.html
the guy above me is correct about the converter
DS length will more than likely be different, see thread
what type of VSS adapter is it? im thinking it should, but need to see or better understand what you have
