Tranny thoughts on 1-2 slip
Old Nov 25, 2007 | 09:53 PM
00cls1camaross's Avatar
Default Tranny thoughts on 1-2 slip
I have a 4L60E with 60k in 7 years. It has a 4000 stall for about 5000 miles. Once at the track 2 years ago it bounced off the rev limiter from 1-2, another time 6 months ago, and then just for the first time with the stall. I drove the car hard a week ago and raced it 6 times in 3 hours and it never slipped, it looked like it shifted though a little bit after 6000 like 6150ish and it is rev limited @ 6000.
i guess my question is if it is normal to have a slip shift here and there or is that a sign of wear?
thanks
dakota
Old Nov 25, 2007 | 10:01 PM
Gilbert@Ace Racing's Avatar
You are experiencing the effects of a worn transmission.
It is normal to see odd shift feel symptoms on high mileage units that have been driven hard. It's the nature of having a performance vehicle.
g
Old Nov 25, 2007 | 11:22 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like you should be considering a trans from one of us . You have run it hard
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 26, 2007 | 08:10 AM
firechicken_98's Avatar
Try flushing or changing the fluid first before assuming that the trans is going out. I have seen this take care of that issue on more than one occasion. Always check the simple things first. If that doesn't work then you know there are other issues.
Old Nov 26, 2007 | 10:33 AM
I did 5000 miles ago. the guy that put on my stall said there was just normal wear and tear from looking at the fluid. like it said, it just happens every once and a while that i didnt know if it mattered
Old Nov 26, 2007 | 10:39 AM
LS1Tech Sponsor
Well if you had it flushed that recently I would have to stay with the trans is just showing signs of wear and its getting close to time to replace it
__________________
Call 888-744-6542
