4.10s and stock converter? I'm doing a swap right now with an LS1 and the chassis it's going into has a 4.10 rear end from the factory. Eventually I plan on changing the gears to something a little more cruise friendly (wife's daily driver) but that's pretty far down on the list of expendatures (after making it run, drive, etc). My biggest concern is pushing through the brakes or having to lay into the brake pedal hard to hold it at lights. Not sure if I need to loosen it up to get away with those gears. I was thinking about a Z06 cam but if I have to get a looser converter anyway I might go slightly larger. |
If the car is on stock Heads and Cam I see no reason why gears would make the car push through the brakes. Even with a a ZO6 cam I wouldn't think you would need a converter. I mean a converter would be one of my first mods even before gears but thats just me. |
I'm not denying that a converter isn't the best bang for the buck... but the car has 4.10s. I'm going to change them out for something in the mid-3.xxs when the opportunity presents itself. Mostly just trying to justify a converter to myself. I want one... but the car wont need one to do what I want. |
If anything I would think it would push less.. your engine won't be as loaded from idle to keep the car running. - I could be completely wrong, just my thoughts. |
others have done 4.10s and a stock converter with no problem. Just remember with a stock cam, your A4 should idle around 600 rpm rather than the 800 rpm of your M6. Fixing the idle will eliminate any push through issues. A z06 cam will idle fine at 650 to no higher than 700 rpm with a stock converter when tuned. |
Originally Posted by 1Bad00SS
(Post 8222320)
Originally Posted by Ragtop 99
(Post 8223476)
others have done 4.10s and a stock converter with no problem. Just remember with a stock cam, your A4 should idle around 600 rpm rather than the 800 rpm of your M6. Fixing the idle will eliminate any push through issues. A z06 cam will idle fine at 650 to no higher than 700 rpm with a stock converter when tuned. It's the baby hauling/ass hauling Bavarian family wagon my wife will be using as a daily. The exhaust note is going to give away what's under the hood anyway... so it's tempting to make it have some lump. |
Give some thought to how you are really going to drive this. You have the rare opportunity to match the cam, converter, and gears and make a combo that does what you want without compromises. |
© 2024 MH Sub I, LLC dba Internet Brands
