Question on installing a 3500 Stall Torque Converter on a A4
Old Jun 23, 2003 | 03:53 PM
Raben's Avatar
Default Question on installing a 3500 Stall Torque Converter on a A4
Hey gang. I have a 99 nearly stock LS1 T/A. I'll be putting in a 3500 stall PCI converter along with a Trans Go Shift kit, Drive shaft loop and B & M (believe that's it) Tranny cooler here really soon.
Is there anything else I need to look into getting for this setup to work? I've heard about the computer thinking the converter is slipping with such a higher stall but wouldn't the shift kit resolve that issue?
Thanks
Old Jun 23, 2003 | 04:25 PM
ShadowLightCSU's Avatar
Default Re: Question on installing a 3500 Stall Torque Converter on a A4
Only the newer cars have problems with higher stalls, you will be fine.
Old Jun 23, 2003 | 04:52 PM
boomcase's Avatar
I would sell the trans go shift kit and do somekind of programmer so you can play with the shiftpoints and raise the stock rev limiter.
Old Jun 24, 2003 | 07:38 AM
Ragtop 99's Avatar
I would do the shift kit if you want the higher line pressure AND get Edit to adjust shift points, lock-up, engine tuning, etc.
Old Jun 24, 2003 | 09:08 PM
Stone0fFire's Avatar
cant you just get a programmer to adjust shift points, lockup, AND increase the shift firmness instead of buying the editor AND having to buy a shift kit also?
Old Jun 25, 2003 | 07:22 AM
Ragtop 99's Avatar
yes you can electronically boost line pressure, but a properly installed shift kit is the better way to achieve that goal, especially if you want a significant increase in shift firmness. For just a tad increase, doing it electronically is fine.
