flywheel the same on LT1 and LS1s? HELP
Old Dec 3, 2007 | 10:18 PM
94BlackSSClone's Avatar
Default flywheel the same on LT1 and LS1s? HELP
I bought a 3000 stall ptc converter which I am now trying to sell and I need to know if they are the same. I ordered and know that it is for the 4L60E and an LT1 but will it go on an LS1 as well?
Old Dec 4, 2007 | 12:56 AM
8a8mfh's Avatar
It won't work with an LS1 4L60E.
You'll need to use an LT1 or any older style 4L60E. It will also require a flexplate that will bolt to an LS1 with the LT1 TC bolt pattern, and also a converter pilot spacer.
