Vigilante Triple disk vs Single disk....difference??
Old Dec 15, 2007 | 12:20 PM
Kenny H's Avatar
Default Vigilante Triple disk vs Single disk....difference??
Explain to this transmission idiot what the difference is and would the triple disk be needed for a cam-only set-up looking to dip into the high 11s??
Old Dec 15, 2007 | 02:00 PM
performabuilt's Avatar
LS1Tech Sponsor
Unless you plan to lock the converter at WOT theres no advantage to the multidisk as your converter normally will only lock at part throttle cruising. And there are very few instances where locking the converter at WOT shows any benifit
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 15, 2007 | 05:10 PM
DeltaT's Avatar
What if you're into roll racing? My 80E/383 combo gained 30rwhp and 25rwt when I engaged the lockup under WOT. I don't understand why this wouldn't make a difference late in a run, or even during a mid-range pull on an FI motor.
Jim
Old Dec 16, 2007 | 06:28 AM
FLT's Avatar
FLT
The advantage in some cases is to allow you to stay in 3rd gear in the 1/4. Meaning if you are running out of RPM's this will allow you to gain some without having to shift in to OD. A gear swap or tire size will help to correct this as well. I myself like the Vig triple or the multi disc. They do lockup very nice on our Dyno. Vince
Old Dec 16, 2007 | 01:07 PM
DanZ28's Avatar
I have seen the single disk slip on some higher TQ vehicles on the dyno when locked up.
Old Dec 25, 2007 | 08:19 PM
c5mtl's Avatar
my tci ssf3500 on my c5 wont stay locked on the dyno and i only have 410 rwhp...tuner told me i have 10percent slip also at w.o.t
Old Dec 26, 2007 | 07:20 PM
Flaco's Avatar
my converter sees plenty of lock-up at wot, pulls harder through the traps too.
