Lock-Up Switch...
Old Dec 16, 2007 | 01:35 PM
projekt70chevelle's Avatar
Default Lock-Up Switch...
I've been having problems with my car going in and out of lock up ever since i've owned it... just now finally realized what it was. So i decided that when i do the tranny temp sensor i might as well replace it. So is this the right one, if so is there a better place to get it?
http://cgi.ebay.com/ebaymotors/2004R...spagenameZWD1V
Old Dec 16, 2007 | 03:17 PM
performabuilt's Avatar
LS1Tech Sponsor
Thats would be areplacement lockup switch, I dount however if our cars been going in and out of lockup thats the problem generally those are either good or bad. If you dropping in and outof lockup you should use a scanner to see whats being commanded , But it certainly wont hurt to change the solenoid
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
