Rollling In Park
Old Dec 17, 2007 | 07:40 PM
00Formula00's Avatar
Default Rollling In Park
Hey,
We just got the new trans in and everything hooked up. We rolled the car out of the garage and the car said it was in park... When I tried to shift with the shifter it felt "empty" and there was no clicking sound from the trans? Do you think it popped out from the floor/shifter?
Old Dec 17, 2007 | 08:35 PM
00BlueTA's Avatar
Did you hook up the linkage on the bottom right?
Old Dec 17, 2007 | 08:43 PM
performabuilt's Avatar
LS1Tech Sponsor
First thing check that it is connected under car, Then verify you will need some help with someone looking under car to see that when you move the shifter inside the car that the level under the car on trans is moving with it, I have seen alotta guys break there shifter cable when removing the old trans.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
