Converter Question help please
Old Jan 20, 2003 | 09:31 AM
LS1 CRAZY's Avatar
Default Converter Question help please
Bought a used car, how do I know what stall converter it has. If I put it in drive and drive it under normal conditions the RPM that it shifts itself at, is this the stall??
Old Jan 20, 2003 | 09:36 AM
Kevin Steele's Avatar
Default Re: Converter Question help please
On the later models you can pull the gearshift selector into manual 2 and hold the footbrake with your left foot and step on the accelerator with you right foot and get the true stall of the converter. You may have to hold the brake firmly and be sure to go all the way to the floor with the accelerator. Just watch the tach and you'll have your true stall.
Kevin
