Fast Toys Now Selling Pro Torque Converters!
Fast Toys is pleased to now be an authorized Pro-Torque high stall torque converter dealers. For those of you not familiar with Pro-Torque, here is some useful information:
Nothing will improve the performance of an automatic equipped car more than a Pro Torque high stall torque converter. Typically automatic equipped cars with sticky tires can achieve up to a half second ET improvement!
ProTorque's Bullet Street/Strip Converters are the perfect all-around
high performance torque converters because they provide the highest
torque multiplication factors of any converter available. They
provide excellent torque multiplication at a lower stall speed providing
superior part throttle driveability and down-track coupling efficiency.
What is the ProTorque difference?
The ProTorque Converters will have many differences from the units produced by the factory and other aftermarket rebuilders, which is what makes it special. We strengthen each converter by furnace brazing the turbine assembly and installing Torrington bearings on stator and pump surfaces in place of the factory thrust washers. We use billet front covers in place of stock stamped covers. The list goes on
What is a performance converter?
A regular torque converter is designed for stock engines. A performance torque converter is designed differently
First we strengthen the torque converter to handle the additional power
Second we alter the characteristics of the torque converter in order to transfer the additional power. Third we adjust stall to more closely match the power curve of a higher performance engine.
Upgrades include:
• Anti Ballooning plate Anti Ballooning plate
• Billet Clutch Billet Clutch
• Billet Cover Billet Cover
• Furnace Brazed Furnace Brazed
• Hardened Splines Hardened Splines
• Welded Turbine Welded Turbine
• Torrington Bearings Torrington Bearings
• Custom Designed Stator
The Best Warranty
ProTorque offers a “No questions asked, Unconditional 60 Day Warranty.” If within 60 days of installing a ProTorque torque converter you are not 100% satisfied with your purchase, we will refund your money for the full purchase price of the product (not including shipping or installation costs). ProTorque offers a free stall adjustment within this 60 day period. If after installation the customer needs to adjust the torque converter for any reason ProTorque will do a free stall adjustment within 60 days of purchase.
In addition, we also offer a 1 year warranty on all of our products. If within one year of purchase you have a problem with a torque converter, for any reason, we will repair it at no charge. This one-year warranty on our products is limited to repairs or replacement by ProTorque of any ProTorque product that fails due to a defect in materials or workmanship. ProTorque’s sole obligation under this warranty shall be to repair or replace as its option, the defected converter at no charge to the original customer.
Stall Speed & HP Ratings
The 9.5" Pro Torque Conveter will be built based on your stall speed spefications. We will contact you at time of order to discuss your vehicle modifications and goals. The 9.5" unit is rated up to 650 HP!
You can find more information about Pro-Torque converters in the Transmission section of our online catalog.
Thanks!
Upgrades include:
The Best Warranty
Thanks!
