Need help on stall speed.
Old Dec 21, 2007 | 09:17 PM
1998TA__1991RS's Avatar
Default Need help on stall speed.
im about to go from a 4600 converter in a 4l60e to a th400. I need help on deciding what stall speed is right for me. Im running a forged 347 with a T-Rex cam, 4.10 gears, and a 28" tall tire, i also plan to spray around a 200 shot some. the car sees a little bit of street driving, maybe 50 miles a month or so. what stall speed do you reccommend i go with with the th400. also the th400 will have a trans brake. thanks
Old Dec 21, 2007 | 09:47 PM
Omega Doom's Avatar
unfortunately you can't have the best of both worlds so you either build the combo around nitrous or N/A, you can make it for N/A and then just spray it but for the upmost performance you have to choose! so that being said probably a nitrous 3500 or stall would be best!
