M6-a4 Reverse Lights ?
Old Dec 25, 2007 | 05:33 PM
CAMARO_THUNDER's Avatar
Default M6-a4 Reverse Lights ?
Which connector/color wires come from the m6 harness that plugged into the M6 do I use to connect to my A4 shifter ?
Old Dec 25, 2007 | 05:50 PM
8a8mfh's Avatar
There are three connectors that plugged into the M6, CAGS solenoid, reverse lockout, these both have a square looking plug.
The reverse lights have a plug with two round prongs.
To put it another way cags and rev lockout use the same type plug, rev lights use a different plug. So out of the three that went to the M6 it's the different one.
You can also turn the key on and put a jumper wire between the two terminals, the reverse lights will come on if you have the right one.
Old Dec 26, 2007 | 08:40 AM
Thanks
