flexplate??????
Old Dec 25, 2007 | 07:07 PM
bonnarls1's Avatar
Default flexplate??????
i have a 2000 ls1 firebird i'm putting a th350 in it,just wondering what flexplate i should go with? thanks
Old Dec 28, 2007 | 08:12 AM
Kevin Winstead's Avatar
Hi,
I recommend the TCI 399753. It includes the correct pilot extension and the small GM bolt pattern as well.
Old Dec 28, 2007 | 12:41 PM
radz282003's Avatar
I don't know if that year had problems but I thought I remembered the 2002s (and maybe earlier) models had cracking problems. It happened to my brothers car while he was driving on the freeway. Don't replace it with a used one from that year!
Old Dec 28, 2007 | 04:46 PM
Carshopinc.com's Avatar
LS1TECH Sponsor
The easiest route would be the TCI Piece, You can also order a custom converter for your application and elongate the mounting bolt holes. Last option is to locate a 6.0 Non dished flex and a spacer....
