th350 to ls engine
Old Dec 26, 2007 | 04:17 PM
SlowZ28/SS's Avatar
Default th350 to ls engine
Wondering what all is needed to bolt a th350 to a ls1. I know you can get some of the parts from GM but i dont know if there is certain items that are only aftermarket.
Old Dec 26, 2007 | 04:19 PM
jay_lt4's Avatar
all you need is the hughes crank spacer, do a search , it has been posted many times
Old Dec 26, 2007 | 04:21 PM
GrahamHill's Avatar
I used a converter already ready already for the extended snout, a flexplate from a 98 LS1 since they have both bolt patterns, BMR crossmember, and the trans had a t/a mount bolted to the BnM transmission. I used a BnM megashifter sitting in an M6 console piece.
Old Dec 26, 2007 | 04:53 PM
SlowZ28/SS's Avatar
thanks for the info
