TH400 and converter questions
"Typical TCI® Super StreetFighter™ transmission features: Red Eagle® clutches, Kolene® treated steel plates, Red Eagle®-lined, extra-wide Powerbands™, larger diameter servo assemblies, an improved lubrication system, new sprags/roller clutches (upgraded in certain models), enhanced hard parts where applicable, chrome-plated, TCI®-logo transmission pan, increased thrust capacity, higher line pressure for extra firm shifts & greater torque capacity with less slippage, as well as being TCI® factory blueprinted, inspected and dyno tested. "
What do you guys think about this transmission for a D1sc Procharger setup on a street/strip car??? It would be about 12#'s boost, 346 c.i., nothing too fancy. I'm still on the fence a little about the whole T56 to TH400 swap.
And the guy there spec'd a 3500 stall 2.2 str converter for a 232/240 115lsa cam (EPP blower cam), 3.73 rear gear. Opinions?
Thanks
Andy
