Torque converter hard to turn on input shaft when fully on..
I put them on 3 clicks and its hard to turn the converter, It does spin but not freely.. On 2 clicks it spins freely.
Others said theirs spun freely with no problems. I took the trans out in park but then did move that gear selecter around a bit when unhooking the linkeage..
Should I be worried?
... Ron
I recall the end shaft with splines, then the middle part with splines, then 2 grooves at the very end.
How can they be damaged? Like, what causes damage to them?
