4L60E...Problems (LT1)
Old Jan 4, 2008 | 04:25 PM
BiggO's Avatar
Default 4L60E...Problems (LT1)
Hey, im helpin a buddy of mine work on his 93' Camaro..As soon as tha car moves tha trans shift from 1st-2nd-3rd then 4th..real quick lik .Also tha convertor stays locked in every gear....
Old Jan 4, 2008 | 04:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Unhook the electrical connector from the trans temporarily should disable lockup, Then tighten the TV cable till you get the desired shift timing . When you get done with that holler back . And we can look at the Lockup issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
