How cool is too cool for transmission?
Old Jul 3, 2003 | 06:55 AM
Larry's Avatar
Default How cool is too cool for transmission?
Is it bad for your transmission to make a full throttle pass cold? How warm should the tranny be before making a pass?
Old Jul 6, 2003 | 06:05 PM
Toxic Texan's Avatar
Default Re: How cool is too cool for transmission?
I am not sure Larry. I know when I run at the track the tranny temp is between 120-140. When I finish my run the tranny is 160-175. Hope this helps.
Old Jul 7, 2003 | 12:10 AM
highgear's Avatar
Check the TCI website. Seems I saw where they said to bypass the radiator cooler and go directly to trans cooler to keep the temp below 175.
Old Jul 7, 2003 | 07:36 AM
Larry's Avatar
Joshua,
120 sounds good. I wonder if winter temperatures and having sat for awhile will be a problem. Tranny might be 70 degrees in 50 degree weather after a cool down. Might have to change my cooler plumbing.
I have just started using Auto Tap and never knew what my temps were running until this summer.
